New Here and could use some help 1982 K10
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Agreed, your crossmember should be dropped down from the frame.
Rusty Nail
Rusty
350sbc
Spacers = washers or similar here + and with longer bolts in the trans mount I think will do it.
The exhaust will not work like that. It will need a bend put in that piece to clear driveline extension. Jack it up and see for yourself. Leave the front tires on the ground...
That looks scary as hell from here. I thought 4 inch lift was all you could do without driveshaft mod..you simply MUST know how much spline in inside there. Spray paint that connection or mark it some way and disassemble it. Return with those pics. See how much has pulled out? There better be at least that much left in there.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
This is how mine is with 6” lift. The spacers are factory but not in original position.
Billyjoe12
Phoenix
Billy
How do you post on here?
Billyjoe12
Phoenix
Billy
No like make my own post I've been looking everywhere on here and can't find a way to post a topic
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Go to the section you want and hit the “ start tread” button
Billyjoe12
Phoenix
Billy
Thank you. I got it. Appreciate it!
NineLine89
Florida
Joshua
The bolts you are referring to are the 4 bolts holding the crossmember to the frame correct? As far as the transmission mount it doesn’t look broken to me.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yes mine originally had the spacers between the nut and the cross member and I moved the spacers to between the frame and cross member
Jrgunn5150
Ionia Mi
J.R.
6.slow
Correct, there should be a gap between the crossmember and frame.
NineLine89
Florida
Joshua
Alright guys am not sure if there is a spacer on the other side of the frame but if so I will swap them to between the frame and the crossmember. Also is 2” of extension on the front drive shaft ok ?
Rusty Nail
Rusty
350sbc
If you mean there are 2 inches left in that shaft, past the line you marked, then yes, that should be fine. I knoe some people run lots less than that and I knew it was there, but you needed to think about it.
I would be madder than hell if all you dudes kept posting in MY thread....maybe some kind-hearted MOD will clean this up for you.
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Welcome sir.. I'm not into 4X4 driving, breaking and building.. But being as I'm an old fart, I can help you with the bind.. When I'm in a bind, EX-lax works every time..:poop::insane:
You sir, win comment of the day!
chevelless07
