nvrenuf
- Jul 30, 2010
- Mobile, Al.
- John
- K5
The 2 pc magnesium inserts were used on the 8 bolt wheels. I'm not sure but either with the introduction of the 12 bolt wheel or at least during production they changed to 1 pc rubber.
You do have to be careful about cutting the mag inserts as it's flammable and extrememly difficult to extinguish. Obviously a cutting torch is out but the common way to cut them is to use a sawzall with a wood cutting blade. Once cut, use a grinder with a flap disc to sand and smooth out the sharp corners and whatnot. This is the way I did mine, it took about 1.5 hrs to do 5 wheels.
I think you can cut the rubber style down the same way but I've never done it.
