PDSM
- Dec 18, 2016
- Huntsville, AL
- Russ
- C10
Hi Folks,
I just bought a '76 C10 pickup, and have been searching the web for answers to a few questions I have about the truck. Fortunately, I stumbled across gmsquarebody.com, and found the answers to all but one of those questions. THANKS!
Now for the question I didn't find an answer to... My power steering pump belts are seriously out of alignment, not just that the pulleys aren't coplanar, but also that the pump's axis does not appear to be parallel to the crankshaft. When I started digging into it I found that someone had added a roughly 1/4" thick spacer to the driver's side pump bracket where the adjustment slot is. No wonder they're misaligned, right? (sorry, I didn't think to take a picture at that stage.)
At this point I should mention that my truck was originally equipped with a 350 engine, power steering and air conditioning. The previous owner had the engine replaced with a GM Goodwrench crate 350 with long water pump, which if I understand correctly should be right for the truck. I assume, but really don't know for sure, that he just reused the accessories and brackets and such from the old engine.
So I take it all loose to try to get everything back in alignment, and I think I understand why he added the spacer. (Not that it was the right thing to do, but the reason he did it...) When I took out the spacer, the top rear edge of the PS pump reservoir hits the lower edge of the a/c compressor bracket that is bolted to the head. See attached photo "Interference with ac compressor bracket"
So the interference between the reservoir and the compressor bracket makes for about a 3/8" gap between the PS pump bracket and where it's supposed to attach. I guess he just filled in the gap with that spacer, clamped it down, and went his merry way.
If I rotate the pump clockwise to the point that the reservoir is below the bracket and doesn't interfere, it appears that the pulleys will line up pretty well. See attached photo "Too low 1." The problem with that is that the top edge of the PS adjusting slot is about 1/2" below the bolt hole, so it can't work that way. See "Too low 2."
I wondered if along they way the PO had used incorrect brackets, but in looking at the illustrations in the service manual, it appears that I have all the correct mounting brackets for this model year and option combination.
I also noticed that in the '74 manual it shows a different style reservoir with an oval cross section (like this: https://www.napaonline.com/napa/en/p/NSP816635F/NSP816635F_0212493958)
whereas in the '76 supplement it has the typical squarish teardrop shape that I'm most familiar with (and is what is on this truck.) In looking at RockAuto and other such places it seems like the oval reservoir may be more correct for trucks through '72, but I'm not sure. It does appear that this reservoir is slanted forward so it may give me more clearance for the compressor bracket.
Have any of you ever had this interference problem? If you have a similar configuration (350 V-8 with PS and A/C) what type of PS reservoir do you have?
Thanks for your help!
