Need obscure bearing
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Alright, I know this may sound like a crazy long shot but I've gotta try. i have an old kohler motor with a knocky main bearing. So after some digging I found that the crank diameter is 1.65 inches and the main bearing inner diameter for it is 1.75 inches. If anyone knows of any manufactured bearing that ever existed with a 1.75 inch inner diameter, PLEASE shout it out:Big Laugh: or if anyone knows of some trick to fix this bearing or make a new one, that'd be greatly appreciated. They sell these bearings but they're mostly used on ebay and cost upwards of 50 bucks, way too much for me to spend on some junky motor. Part number is #48 030 06-S. Again any advice is appreciated:favorites37:
Attached are photos of my victim
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Lol I like the challenge, only 35 bucks on craigslist. Im hoping to make a generator and give it my spare 20 gal long bed tank and just tuck it away when im done. Theyre worth like 200 bucks on ebay too so i figure if it doesn't work out il just flip it
WFO
Texas Panhandle
A Bearing Supply House ought'a carry those.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
So possibly $50 for the correct part on top of the $35 you paid for an engine that can be flipped for $200? What's the problem?
Back when I was fixing in-home appliances it was common to run into the homeowner that didn't want to pay for the necessary part to fix his dishwasher or whatever I was working on. I'd tell 'em they needed a new $60 fill valve for instance, and they'd look at it and say it didn't look like a $60 part. I'd hand it to them and say "Go make one of these in your garage and then tell me what it's worth." They always bought the part.
fmxr47
US
Justin
Because Kohlers are expensive to fix!
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Anyone know of any good ones of those? Or any motor that's used a 1.75 bearing? Crank, cam, rod, whatever. Anything will work lol. Half of me is considering just sending it with the Damn knock
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
That was my original thought as well until I looked at a picture of it. It's more of a bushing than a typical roller bearing so not something you would find just sitting on the shelf at a bearing supply house. Lots of sites list it as nla so the op should be happy that it can be found at all. There's no cheap way around it so Ob is going to have to decide just how much he wants to fix it and if it's worth it to him.
  • Like
Reactions: WFO
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
A good machinist can make anything. Also sit with a parts book for a while and I’m sure something could be cross referenced with good measurements.
  • Like
Reactions: WFO
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Yea sofar ive found an austin Martin motor with the same size, but too obscure. And i found a post from a guy saying he ran a 1.75 rod bearing in his honda k24a, but then said it was an ls bearing. Is anyone familiar with what he may be talking about?
rt66paul
California
paul
1991 suburban
http://www.psep.biz/store/kohler_engine_parts.htm
It has been my experience that bearings, brake rebuild kits, rings and even pistons can be found to work in many different applications. Why make a special bearing when it can be designed to work just as well with a standard part? IH trucks, almost all farm equipment, Willys and Harley Davidson build with standard parts and in a pinch, can be made to work with metric parts. How do you think Cuba kept so many old cars, equipment and motorcycles running? They used Russian parts.
yevgenievich
Place
Name
Year
Model
Size
That is right around 45mm id which is a relatively standard metric size for a bearing.
I have cross swapped metric vs standard before but not on an engine application
thatgermanguy
