Velder
- May 26, 2023
- Tx
- Christian
- c10
Hello all,
Been a while since I was last on, but I have got my truck running now and need someone familiar with Quadrajets to give me some advice.
Some of y'all recommended that I try rebuilding it a second time, which I did, and now it actually runs pretty good. Lots of power, great throttle response, and pulls about 18in of vacuum at idle in drive. But I also installed an AFR gauge, and that would indicate that I am running lean pretty much across the rpm range. I am floating at about 13 at idle in drive, and between 14-16 when driving at about 50-55mph. When I step on the gas it will drop to 11-12 very briefly before jumping right back to 15.
So here is my real question; Is this normal for a quad? or am I running really lean?
As an aside, when I first installed the AFR, it would only read above 18, finally figured out it was the A.I.R. system pumping in fresh air into the exhaust. I have disabled that system just by removing the air pump belt. But the EGR is still fully intact.
I have set my timing to the recommended 4deg. initial with the vac. advance disconnected, so total timing comes out to about 25deg at idle.
As always any advice, suggestions, recommendations, or instructions are greatly appreciated.
