Need A Tach
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Hey guys. Iv got a 6.2L powered R30 and I would really like to have a tach. Did they have factory tachs in a 6.2? If not, how would I go about an aftermarket one?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
2+ ton up trucks with diesels could have a factory tach, I'm not sure how it is controlled though.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Ooo I REALLY like that cluster! If its got the same motor then it "should" work... in theory lol
chengny
I believe that the impulse for the tach on the 80's diesels was taken from the alternator. It's easy if you have the correct alternator.
From some other place:
hi,here is the post location ,I included both styles of alt either one ,should have the R terminal as for a tach wire.....guy..
in that case there is no hook up for a tach on your alternator ,in that case you may have to either get an alt with the tach post on it or if there is an alt starter rebuilder in your area have them install one on it ,which would be cheaper to do than buying one .or if a junk yard has one ...guy..
And a link to a long discussion:
http://www.dieselplace.com/forum/63...iesel-engine/198847-alternator-lead-tach.html
RetroC10Sport
Jay
pontiac aztek
Most were Detroit Diesels, but in all honesty, I can't see it not working on a 6.2 with a little modding.
MrMarty51
Eastern Montana
Martin
6.2, I`m not sure.
A lot of the diesels I worked on had a magnet attached to the flywheel, for the signal generator, sensor was screwed into the bell housing. The 8.3 liter Detroit diesels were all made that way.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
The 6.2 is a Detroit diesel as well if I'm not mistaken. If that is the case, shouldn't be too hard to adapt something.
99tan99
