How much? I got a compressor for Christmas and going to be getting some air tools.
Mine puts out 5.1@90psi or 6.3@40psiFound the specs. Not bad. 5 cfm, but that doesn't say at what pressure. Usually you want air tools regulated at 90psi.
As if the 2135Ti wasn’t already the best 1/2” air impactool™ you can buy, we decided to make it even better. Perfect for both industrial and vehicle service work, the new 2135TiMAX delivers maximum power and control, along with unmatched reliability.
• MAX Power 780 ft-lb maximum reverse torque from a tool weighing just 3.95 lbs — that’s the best power-to-weight ratio in its class
• MAX Control A featherable trigger, a wider range of power regulator settings in forward, and a patented one-hand forward/reverse
• MAX Reliability Designed to last and backed by a new 2 year limited warranty, Tool registration required. Specifications:
• Forward Torque Range: 50 – 550 ft-lb
• Max Torque (Reverse): 780 ft-lb
• NBT (Nut Busting Torque): 1,100 ft-lb
• Blows Per Minute: 1,250
• Free Speed: 9,800 rpm
• Standard Bolt Capacity: 9/16”
• Net Weight (2135TiM AX): 3.95 lb
• Overall Length (2135TiMAX): 7.34”
• Average Air Consumption @ Load: 5 cfm
• Air Inlet: 1/4”
• Minimum Hose Size: 3/8”
Damn, that twice what I guessed.$319 at sears. Havent used it yet but Im glad to hear its strong!
They had some for half the price but they were only 400 ft lbs. I wanted something that I wouldnt have to worry
