my new toy
1low4x4
Nick
780 lbs of torque
towman
harrisburg pa
jay
v10
i have the same gun they are plenty strong use it all day at work
I've always had great luck with Ingersol Rand aka Devilbiss Air Tools, and compressors too for that matter. Campbell Hausfield on the hand, junk tools and compressors.
J Knight
Baytown TX
82 Chevy
350ci
How much? I got a compressor for Christmas and going to be getting some air tools.
Better be a good compressor to run that tool. Unless you give it lots of breaks to build up air. I'd guess at least 10.0 cfm @ 90lbs to run that one.
You got the usage specs there on the box Nick???
Found the specs. Not bad. 5 cfm, but that doesn't say at what pressure. Usually you want air tools regulated at 90psi.
As if the 2135Ti wasn’t already the best 1/2” air impactool™ you can buy, we decided to make it even better. Perfect for both industrial and vehicle service work, the new 2135TiMAX delivers maximum power and control, along with unmatched reliability.
• MAX Power 780 ft-lb maximum reverse torque from a tool weighing just 3.95 lbs — that’s the best power-to-weight ratio in its class
• MAX Control A featherable trigger, a wider range of power regulator settings in forward, and a patented one-hand forward/reverse
• MAX Reliability Designed to last and backed by a new 2 year limited warranty, Tool registration required. Specifications:
• Forward Torque Range: 50 – 550 ft-lb
• Max Torque (Reverse): 780 ft-lb
• NBT (Nut Busting Torque): 1,100 ft-lb
• Blows Per Minute: 1,250
• Free Speed: 9,800 rpm
• Standard Bolt Capacity: 9/16”
• Net Weight (2135TiM AX): 3.95 lb
• Overall Length (2135TiMAX): 7.34”
• Average Air Consumption @ Load: 5 cfm
• Air Inlet: 1/4”
• Minimum Hose Size: 3/8”
1low4x4
Nick
$319 at sears. Havent used it yet but Im glad to hear its strong!
J Knight
Baytown TX
82 Chevy
350ci
• Air Inlet: 1/4”
Mine puts out 5.1@90psi or 6.3@40psi
Damn, that twice what I guessed.
1low4x4
Nick
They had some for half the price but they were only 400 ft lbs. I wanted something that I wouldnt have to worry
Worry about? You might have to worry about breaking your damn hand, or breaking it off at your wrist. :laughing1:
You will like that one, they are good guns for sure.
83K5guy
Corpus
Justin
K5 Blazer
Those are nice guns. I have one and does anything I have needed it to do and I have had some pretty rusty and tight bolts
X-cabsquarebody
Western NC
Billy
C10, C10 ,K30 , 3500
305 TPI, 454, 8.1
There great. If its to rusty to get off, it will break it off. Ether way its coming off!
MrMarty51
Eastern Montana
Martin
Been using that same model wrench for over twenty years.Had to replace the socket retainer on the anvil once.
The shop I worked in had the exact wrench,the anvil/square drive busted,they dumpstered it,I grabbed it up,bought a new anvil,its as good as new,and,I now have a spare.
After twenty years of abuse,the only problem I`m having with My original impacter is,the little red switches wants to pop out,shove it back into its hole and it`s good to go.
The shop I was in run 150 PSI,that impact would,with a 1& a 1/2 inch socket spin truck lugnots to over 750 ft/lbs,had to be carefull.LOL
Call ingersol,tell them how much You like using their tools,I did,they sent Me a little mimni grease gun,two tubes of the special grease,a bottle of air oil and a spare anvil/socket retainer kit.
I do,real regularly use the grease gun,keep it lubed,just a couple of pumps,too much grease and it wont hit as hard for a few raps.
78silverado
