- Apr 11, 2017
- kansas
- Rick
- c20
The pinion bearing is going to be the same spec. Nbd.I was super paranoid on my first rear gear set but after once it was a cake walk don't let anyone scare you, your old pinion shim is probably going to be the right one. You will need a dial indicator and the inch pound torque wrench. But really not a big deal. I would suggest new ring gear bolts and loctite on the ring gear bolts, I have had a problem once reusing ring gear bolts, and you know once bitten twice shy. Be sure you use a torque wrench on your ring gear bolts and carrier bolts. Proper preload is the torque on the pinion nut.Meaning when your preload is right that's it, no tighter.This really is NBD
