- Apr 11, 2017
- kansas
- Rick
- c20
If you use all New bearings and pinion shim than, no you won't have to pull any bearings. Going back on freeze the diff and pinion in the freezer heat the bearings in the oven and they will fall right on or take a few light taps with a hammer and a punch or a piece of pipe.But you could use the bearing press jack allthread set up to push it together too.Id still heat and cool, for less interference.
