my 88 k1500, tons of pics
Does the Skull hitch cover, his eyes light up when you hit the brakes? Thanks for the pics. :popcorn:
Swims350
Logan WV
none
yea but it's not hooked up, it's also not in the hitch, I got it bolted to the bumper. I took the hitch off last sept. when I pulled the bed, and never put it back on. We don't tow, nor own a trailer or anything so I had no need for it, plus it saves weight lol. I kept it just in case I need it or want to sell it sometime.
Swims350
Logan WV
none
more pics........
I got some plug wires rerotued and pics of the other chrome stuff I put on awhile back. I got rid of some unwanted/unused wiring and plugins and then cleaned up and hide some others, then I gotta get some new wires, or at least a couple so I can replace the too short to tuck under no. 1 wire.
You definitely likez da chrome :handshake: Engine compartment looks good :)
Swims350
Logan WV
none
you know it man. Always loved it. I would do the chrome hoses but man they aint cheap. They got rad. heater, vac. fuel, everything now in the chrome ones with chrome ends, but man they are expensive.
Good **** dawg. I see the heads are a different color than the block. You have to change them or you just paint it that way on poipose? :popcorn:
Swims350
Logan WV
none
I painted em that way lol, looks like alum. heads. My old man loves it lol. I could care less, I'm good with orange. I was only really planning to redo the intake, and the water pump, and leave the block and heads alone unless I notice alot of bad spots or something.
Is that electrical tape I see on the #1 plug wire boot? :popcorn:
Swims350
Logan WV
none
yea LOL. it got a split in it, I slapped some tape over it, it was only about a 1/4 spilt, thus why I want another set or at least a couple wires, plus now it's too short to tuck under the headers, and the other side has a straight boot too. I want just 90's and that's it. Now that you can't really see em, I don't care what color they are either. used to I always wanted yellow only cuz you could see em. Now that I started doing em this way, love it, it's clean, and neat, plus it doesn't cost anything, I like looms to hold em, but this is free and looks maybe better to me then looms, not sure.
I still gotta do the new upper and lower hoses, t-stat and chrome water neck, wanting to do it when I clean and paint the intake, and move the temp. sending unit wire too, route it under the headers or soemthing, do it all at once so I don't have to drain the cooling system a bunch of times.
I got mostly water in it now, the upper sprang a leak last week or so, luckily I could just trim off about an inch since it was right above the clamp, move the hose down and clamp it, now it's working fine. I don't trust them though, they've been on it since before I got the truck.
They got those chrome thermostat housings too with the o-ring seal.
Swims350
Logan WV
none
yep already got one.
I guess I never added pics in this thread of the parts I got...
about half of those are already on of course. i gotta do the fp block off, the valve covers, t-stat, water neck, hoses, then the rest gets used, wing bolts, gaskets, grommets and breather.
:waytogo: :drool: :popcorn:
Swims350
Logan WV
none
if my old man gets his truck aligned I'll actually be able to get more done. I gotta put a kickdown cable on it too. maybe even do the stage 2 shift kit.
onasunday
