Mounting tires at home
Well I stretched that tire open used 3 spray paint cans spaced at 12/4 and 8 mounted it back up still had to ratchet strap it but it worked. Now just for fun I bolted a center mount bar from a coats 40 40 to a piece of unistrut I had laying around. Ignore the strap hook I just used it as washer. Anyway it works awesome for mounting,so if you have access to a coats center post bar bolt it to some square stock or copy the mount end. So to date I've done a duckbill on a stick,a lucid mod, tried to mod the harbor freight bar,got a coats tireman bar and used a coates 40 40 bar. Most bang for the buck is the 40 40 bar
I've got an old GroundHawg tire sitting in the barn that has had paint cans wedged in there like that for 2-3 years now. It's probably good to mount up now :rofl:
Dmack
Central OR
Dave
@Dmack watch this I'm impressed it doesn't work as good as the coates,but it works fatten it up to 2" I think you'd have something. FWIW my coates bar is 1and 1/4 the hook is 2 " wide.
Thanks for the link. Looks like a decent design other then the flimsy bar. May have to do some experimenting. My current project is a 1970 C20 I have swapped an 84 C10's running gear into. I have some used BFG 31's in going to mount on the ralleys.
Thanks for the link. Looks like a decent design other then the flimsy bar. May have to do some experimenting. My current project is a 1970 C20 I have swapped an 84 C10's running gear into. I have some used BFG 31's in going to mount on the ralleys.[/QUOT
Oh your very welcome. Your project,super cool give me any pointers you can I have a similar project 1984 c10 frame under a 1970 c10. I'd like to learn from your mistakes.Any major hurdles. I'm hoping it's just weld on some frame mounts and everything else will fall in place. Here's a pic of a coats 40 40 bar that's my thump in the hook to give you an idea of hook size. I can get you any other dimensions you need.
thom9719
