gmbellew
- May 27, 2018
- Kansas city
- glen
- suburban 1500
Thanks. What is a SHUNT? Something I can Buy?Should show something? It's late, tomorrow will check a couple vehicles like you have that hooked up.
Using a shunt many vehicles will show a small MA draw. Without it should show a large one...... provided the draw is still present.
Will get back in the morning.
Please tell or PM me. I am tired of this and would like to figure this out. Electrical is my weak side. Very weak!I have a solution but I'm probably getting ahead of myself.
It’s basically a permanent installation of what you’re doing but it goes on the positive side. (I think). It’s used to measure current draw. Common homeowner application would be in a camper so you can see what components use how much current draw. Like to calculate how long your batteries will last. A shunt I’m sure can measure small currents but it’s typically used for larger currents, but you can buy/size them for whatever. I could be wrong in my understanding but I don’t understand what the advantage would be for diagnosing a problem other than having a constantly visible readout until you fix the problem.Thanks. What is a SHUNT? Something I can Buy?![]()
Ok that’s perplexing! You’re doing it right.Ok, I get 0.00 still. I'm guessing this is going to be something I need to leave to experts. I know online help is really hard when
the people that are helping cant see whats in front of them. Im gonna try a different multimeter with the 10A setting and see if
I can get a draw.
You must be registered for see images attachYou must be registered for see images attach
Can monitor electric flow while turning items on and off. A MM on amps works similar except you're not limited to 10 amps or whatever the internal fuse is.@fast 99, I’m learning here, what would be the advantage of installing a shunt to diagnose a presumably single issue like this?
Yes that makes sense. And a shunt is designed to measure large amp flows.Can monitor electric flow while turning items on and off. A MM on amps works similar except you're not limited to 10 amps or whatever the internal fuse is.
Although it probably doesn't apply here, later model vehicles have draws until the systems go to sleep. Some of those have rather high current flow. I got tired of buying $10 fast blow fuses forgetting the meter was set on amps.
Vehicle tested does not have a draw. First picture shows 3.77 amps through the meter with park lamps turned on. Second is the same draw using a shunt, shows 4.0 on MA scale. Third, lights turned off through a shunt, O MA scale. Has same 0 reading without shunt using amps through meter.
Reason I had to use 2 different meters is the internal fuse is blown on the meter that reads MA. lol
The rule of thumb we use for diagnosing is .05 MV or more using a shunt is a draw. Safer to use the negative side not as shown in the pictures.
Hope this helps.
