Module on valve cover? (1986 GMC 350)
carpart67
Nova Scotia, Canada
Justin
K1500
I plan on swapping the valve covers on my 1986 High Sierra. The engine is the original 350. The drivers side valve cover has some sort of relay or module clipped to it with wires running to it. Just wondering if anyone could tell me what it is? I'd like to get some info so I can figure out where to relocate it.
I could likely figure it out after enough research but I figured someone on here probably knows exactly what it is. Any help is appreciated.
carpart67
Nova Scotia, Canada
Justin
K1500
Here she is
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Here she is
What options do you have?
I find it interesting that you have the drop down exhaust manifolds.
carpart67
Nova Scotia, Canada
Justin
K1500
Not a lot. No cruise, or anything. Perhaps it's something to do with emission control? The truck is Canadian and did have an air pump and all that jazz.
Jims86
Patterson,Ca
5.7 TBI
Do you have a 700R4? without an ECM, it may be a lockup relay.
Could you clean it up a bit, and tell us what color the wires are?
carpart67
Nova Scotia, Canada
Justin
K1500
Turbo 350
If I get a chance to clean it up I will post the colors.
Swims350
Logan WV
none
could still be lockup relay then even with a th350, since they had a 350c which was lockup.
honestly though just move it up to the firewall use a self tapping screw and mount it there, wires look long enough, then you can swap valve covers.
Jims86
Patterson,Ca
5.7 TBI
I dont think a 350c was available in 86...allthough, it is Canada.
Swims350
Logan WV
none
84 from what I heard. I could be wrong though.
GorillaHumper
