modern size wheels that fit squarebody chevies
yevgenievich
Place
Name
Year
Model
Size
those look nice actually. always been a fan of those wheels. that took a center bore or was that direct bolt on 15/16 inch?
For 5 lug applications, gmt400 wheels should be a direct bolt in. 6 lug wheels needed center opened up.
yevgenievich
Place
Name
Year
Model
Size
Another set of gmt400 wheels i had on my 85 gmc with conversion lugnuts to use metric nuts for the caps.
ozark plateau
dennis
k5
great stuff! and thank yall. mr bucket, i will never run a wheel spacer, i value my life and my vehicle too much! yevgenievich, thanks for the photos. what year are the wheels that are on the red truck. if i can find the backspacing on those, i can make better (more) calculations
seems another option brought up is toyota wheels. anyone tried that?
yevgenievich
Place
Name
Year
Model
Size
The wheels on the red truck and black truck both from gmt400 92-98 trucks
The wheels on red I know came stock on a 1990s silverado, my dads 96 did.
ozark plateau
dennis
k5
thank yall. those gmt 400 wheels are 15"? did gmt400 have any 16 or 17 inch wheels oem?
every application Ive personally seen is a 1/2 ton 15 inch wheel 5 lug.. or was it 6... i think 5. crap.
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
V10 Suburban/V1500 Suburban/M35 bobbed w/dump/M1010
5.7/5.7/LDT 465-1c/6.2 diesel
I'm looking into this also for my 91 Suburban V1500. In addition to the axle hole size be aware of the Toyota wheels....they are the same lug pattern as the Chevy but I think they are only 12mm studs vs the 14mm on the Chevy Suburban and I think 7/16" on the GMC Suburban. Seems weird that Chevy and GMC would have different size lug nuts...???
cland13
Marvin
350 w/ corvette 113 aluminum heads
These are the wheels I am running on my 84. They are from the older jeeps that are 5 x 5 and they are 16" x 8". They fit well, but need the lower control arms trimmed slightly so the a arm and wheel don't touch during a hard turn.
89GMCJimmy
ivan
Jimmy
This is My 1989 Jimmy 4x4 with 15"x8" wheels they have 3.75" backspacing with 1/4 of space between rim and tie rod ends.
I believe you can have more backspacing with larger diameter rim? I have also seen and read about some K5's with more backspacing.
It may depend on witch tie rods you use. HD Moog vs some smaller aftermarket tie rods.
89GMCJimmy
ivan
Jimmy
Drivers side
ozark plateau
dennis
k5
thanks scoots. i have 15x8 oem now, im wanting larger diameter wheels so i can source 10 ply tires, and a greater choice of tires. it also makes it easier to find larger (as in 17") wheel tire sets from the junk yard.
that sure is a clean underside you got!
ozark plateau
dennis
k5
seems that the toyota wheels will work, but the lug holes must be bored? the I.D. of the toyota wheels are huge enough and backspacing is supposed to be ok?? i cant confirm. if it s only the lug size, thats an easy fix. but i need to confirm info about the toyota wheels as far as size diameter, lug size, center hole diameter, which years and models came with which size wheels , etc:
Jimc21NC
