Joshua Keith
- Aug 28, 2019
- Memphis
- Joshua
- K10
Had found some pretty significant rust on the roof and started looking into rust removal.
I tried Water/vinegar 4:1 but the rust was too heavy for it so I went searching some more.
Came across metal rescue gel. Not the liquid. It goes on really thick and stays in place once you lay plastic over it so it won’t dry out. These are my results after 3 coats. Each coats was covered with plastic for 24 hours and red scotch brite in between. It’s messy but won’t hurt other paint and wipes right off once you put the water hose to it.
Pre-application
1st Coat
2nd Coat
Final Coat
Pre-application
1st Coat
2nd Coat
Final Coat
