Meaning of "Bonus Cab" in 1985
varmit86
Washington
Mark
C30
The 3+3 meaning is 3 people in front and three in the back, GM made these Bouns cab trucks for peole that did not want the rear seat and alot of conversion companies bought them so they could put in the pull out bed as yours appears to have.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Thanks for all the well wishes guys!
It has some engine issues that I'm still trying to figure out, but I drove the 30 miles all the way home. I'll probably make a post about the motor problems soon.
Let us know, maybe we can help. 454??
OsmiumTetroxide
Idaho
Yes! It has a 454 that appears to have been rebuilt. It runs awful at higher rpm, and builds zero oil pressure at idle, 30 pounds when wound up. I've taken the valve covers off, replaced the oil pump, checked for slop in the bearings, and magnet-checked the oil. No signs of a fragged bearing or bad wear, and there's oil on the (badly lapped) rockers, so I don't think I ruined it by driving it home. I assumed the factory gauge was bad before getting it on the road, only to find that it did seem to work once we got it back. It seems like it could be a stuck lifter, or something of the sort. Once I get a little more time I'll tear back into it and make some posts.
OsmiumTetroxide
Idaho
Mine doesn't have a pullout bed, but I wish it did!
OsmiumTetroxide
Idaho
Hey, you're famous. Or at least your truck is..
Can you confirm the placement of that emblem? The pic you posted makes the emblem look like it sits part way above the body line.
Yes, the badge sits right on the body line. It's weird, but like the pictures someone else posted here would indicate, the badge has a lip on one end that slants out to meet with the receding sheet metal. It fits up nicely, although I don't blame you guys for wondering why they would put it there.
OsmiumTetroxide
Idaho
Glad you made it over :handshake: I’m the guy on GMFS who referred you to this sit :High 5:
Thanks man, there is obviously an incredible knowledge base here! I appreciate the invite.
Southcoast85
Sinton, TX
Gary
GMC c10
would look better in my garage, just saying
dabsRus420
