Man this Dash is messed up
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Christmas in July almost...lol. Maybe you left a ground unattached? Check the wire ends too. Sometimes the wires are so corroded they break inside the insulation. Look for green tarnish at the wire ends.... this is the corrosion
CSFJ
I'm thinking this is the likely cause. I just checked the harness out of my '87. the dome picks up power from a plug on the upper left of the fuse block (orange wire). the white ground wire runs to the under dash light bulb, where it is spliced to the grounds the run out to the door switches.
crossy
Pennsville, NJ
the dome/cargo are basically together, they have a separate fuse in the fuse box that could EASILY have gotten blown with a shorted headlight switch.
Jcarrasco314
