LS timing chain and gear
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
Parts showed up today. During tear down I kept and laid out everything.The new timing set came with a tensioner mine did not have one and the cam sprocket is smaller in diameter than my stock one.
Hit me.
2003 L59 5.3 flex fuel
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
anyone anyone ? Bueller Bueller?
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
I did find an answer. It's an upgrade kit in case you want to drill and tap your block and add this chain tensioner/slack killer hot mess of nothing. Stock is absolutely ok with me.
Gen IV has the tensioner. It is garbage and almost always breaks. The 2009 L9H I am rebuilding had it stock and it was broken when I removed the timing cover. I am replacing it with an LS2 chain and the block dampener instead. Early LS engines(like very early LS1's) didn't even have the mounting blocks for a dampener, but hey make an adapter kit that bolts to the cam retainer plate to provide the dampener mounting blocks.
seanhatesregister
