Slooptin
- Mar 6, 2017
- Denver
- Vance
- k30
LS Swap gurus, I'm getting pretty close to pulling the trigger on a 6.0/4l80e combo, but I want to make sure I've got my ducks in a row before I get in over my head
Assumptions:
1. using stock pcm/tcm & wiring harness
2. engine and trans are running when pulled
3. comes with all accessories
4. comes with pedal (if it's not a cable throttle body)
5. no modifications right now to engine or trans. get it running and driving and I can do a cam or whatever down the road
6. reusing NP205 t case
Things I'll need to buy that I know how to source/have figured out:
1. motor mounts
2. NP205 to 4L80e adapter (this also takes care of OSS sensor if the 4L80e I buy doesn't have one)
3. Headers
4. Gauges
5. VSS for NP205 output speedo cable
6. I can reuse my current radiator (doesn't leak & my current 454 doesn't overheat) I'll just need to reuse the LS electric fans or find new ones + shroud & hoses.
7. I'll possibly need to shorten/lengthen driveshafts
8. I can figure out ps hose routing
Things I'm still unsure of:
1. I can use my existing fuel tanks/sending units, I'll just need to source a frame mounted fuel pump/regulator and figure out how to plumb a return (will this require tbi sending units for the tanks?)
2. NP205 "mount". Currently there is a truss rod that connects the 205 to the body of my th400. I'll need to figure out a mount for this
3. will the accessories from a 6.0 truck motor be fine where they are or will they need to be relocated?
4. I'll need to figure out how to run ac lines to/from compressor to/from condenser & drier
5. wiring-wise, if I keep the stock PCM/TCM, the only additional wiring I'll need to do are for the new o2 sensors (if the locations are different and I need to extend wiring), outputs for gauges & obd2 port, alternator/starter, ignition switch, potentially fans, & potentially gas pedal
Anything else I'm missing?
Assumptions:
1. motor mounts
3. Headers
4. Gauges
