Lq4 swap question
Z7master167
Wv
Casey
What Facebook groups are good for c10 builds?
rpcraft
Robert
Jimmy
LS 6.0 364 CID
wv79k10
West Virginia
Daniel
This is not an answer to your current question but wanted to Clarify my previous post on the DD Mounts. They worked great for my application as I’m running the original tranny and t-case in the stock position which makes the engine sit all the way back on the mounts. If it were to go forward it would not clear the cross member. It currently sits about 3/4” behind the cross member. I also added a 1/4” spacer on the clamshell mounts to get the motor up a bit to help with some extra clearance.
I'm just starting a ls swap in my 79 picking up the motor Saturday. And I'm planning on keeping the th350 and 203 transfer case.
So the dirty dingo mounts will be fine for that application and the AC will clear the cross member? The motor is a 6.0 out of a 2004 2500
thatgermanguy
