Lowering a 1984 silverado
Aj Farias
Adilson
Silverado 1500
How much a 1984 can be lowred with out a C nuch, rim size / width and offsett
Bennyt
Surprise
Ben
4-5" if you plan on using it as a truck.
6" flip if you don't plan on carrying much weight. Otherwise you'll have to notch to tow/haul more than a few hundred pounds.
Finkaire
Finkaire
California
Loren
Silverado c10
Consider the ride, my friends truck is lowered with no notch and rides like a buckboard. I’m guessing that’s where the c notch comes into place.
bluex
Spartanburg SC
C15
Nope, depends on how he lowered it an what shocks are on it. A flip doesn't require a notch just to cruise around
bluex
Spartanburg SC
C15
4/6 you can do without a notch depending on how you plan to use it. Don't buy a kit just get the parts an buy good shocks.
More info here: Thread 'Wanna slam that 63-98 C10/C1500? Lets talk about it!' https://www.gmsquarebody.com/threads/wanna-slam-that-63-98-c10-c1500-lets-talk-about-it.38131/
Any off the shelf cast wheel will fit fine. Don't worry about the offset, tire size is more critical unless your paying big money for custom built 3 piece wheels.
Scott91370
Burleson, Tx
Scott
Sierra1500
We did just the axle flip in the rear and no notch is needed and it rides perfectly fine. A little truck like even.
Front we did 3" spindles and 2" springs. This was a little low for in the front so 1.5" springs were put in to level it out.
Scott91370
Burleson, Tx
Scott
Sierra1500
I was going to add a couple of pics to my previous post and forgot...
Soundmound
North Central Washington
Dave
Scottsdale
Front we did 3" spindles and 1.5" springs. This was a little low for in the front so 1" springs were put in to level it out.
What brand did you go with? Looking just how I want mine to sit.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
AJ, I think your truck looks great the way it sits now IMHO
I was thinking the same thing. That, and it's a long bed. To me, short beds look okay lowered, but long beds, not so much.
FireTruck1984
Michigan
Ted
1984 and 1984
Another idea is to Level the Truck not Lower it..
Obullard74
