Loud squeal over 2k rpm need advice
ryanrcf
Ryan
C30
I bought a 79 C30 back in august and as long as ive owned it its made the squeal. Its got a 454 and it runs the way it should no issue except for the squeal. Thought it was belts so i replaced them, they needed it anyway, tightened them up and the sound didn't leave. Tightened them again and a few more times since but it still squeals. Shortly after my power steering pump started to leak so i replaced it with a reman pump and it still squeals. I did the whole thing, lifted the front end and turned the wheel all types of ways like i was told and i understand a reman pump might still squeal a little but it shouldn't be as bad as it is. It almost sounds like a bearing somewhere but before i replace everything my belts touch i figured i would see if anybody had a good idea of whats goin on.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Does it still have a smog pump? That can squeal and sound like a dying chicken lol. Remove belts and turn things by hand and see how things feel and sound.
Doppleganger
OH-MI: Just like it sounds
Can you get it to run high enough it squeals with the hood up? I would use a stethescope or just a long screwdriver to your ear to find the source. My guess is an accessory bearing.
fast 99
Spokane, Washington
Or, mismatched pulleys. Pictures?
PS pump pully should be flush with end of pump shaft.
roger0080
Minnesota
Check the condition of the pulleys. I had a squeal like that once on the alternator, starts in at 53 mph. New belt didn't help. Turns out it was the pulley. If your belts are at or below the top of the pulley groove, they're worn out. With a new pulley, the belt is like 3/32" above the pulley. That fixed it for me (new pulley).
Auburn, Washington
Components will generally make noise at any rpm’s. Squeals are usually belts/pulleys. Especially those that don’t start until they’re moving faster.
We can’t find the squeal for you, online, lol.
Rev it up in park, listen, spray water on suspect belt(s) if it goes away momentarily you found the source.
And no, new steering pumps aren’t supposed to “squeal a little”. Stop taking any automotive advice from whoever told you that.
CATXTraveler
Dallas
Run one belt at a time and rev it up. See if that helps isolate the noise so you can rule out parts like alternator, PS pump, AC compressor (if you have one) etc.
If you engine is very cold, you can get away running no belts and rev it up to make sure that it's part of your accessories making the noise, but don't do this for very long since your water pump won't be turning. Remove all belts, fire it up, rev, shut it off. If no noise, start adding belts on at a time until the noise comes back. Then you will know where to start.
I use the same trick as @Grit dog a spray bottle of water and another is runnwith no belts at all temporarily,make sure the squeal is gone with no belts. Overtightening belts is not a good idea,it leads to failure of waterpump,alternator,and power steering pumps.
fast 99
Spokane, Washington
Did you check diameters yet? With all the variations available a mismatched water pump, crank, or PS pully diameter is easy to do.
Ask me how I know that. One of those learning experiences.
Joe Voter
Your sister's closet
Joe
Delta 88
Obviously removing the drive belts one at a time in attempt to eliminate the sound wil be the most prudent means to pinpoint the culprit.
My vote is water pump.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
I would confirm that the crank and PS pulley have the same profile as well as the belt. just went through this with my "83 6.2 as someone had installed an AC PS pump on a non AC engine. the pulleys are not the same and they require different belts and pulleys.AC has a dual pulley and non AC uses a single pulley. Crank pulley needs to be correct as well due to the different belt profile.
It's real easy to find a squeeling belt,a little soap and water in a spray bottle the squeal will go away temporarily when you find the offending belt. Then you need to diagnose why? But you will know which belt.
seanhatesregister
