Looks like no compression on 4,6,8
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
I guess this is why my truck cranks but doesn’t start lol . I guess I need new engine?! I havent done leak down test but this sux
MarineOne
Western New York
Have you checked rocker adjustment?
Maknwine
Virginia
Tom
c30
No I have not sir. Thanks for the advice
I agree with Marineone, I bet you got a couple valves not closing. Mine had a stuck exhaust valve and I had zero compression on the cylinder.
Good luck.
85K304SPD
Las Cruces, NM
Richard
Maybe a head gasket issue.
Hugomartin
Banned
Nc
Hugo
Finally have a day off how should I start the process of rocker arm adjustments.
Hugomartin
Banned
Nc
Hugo
When adjusting a cylinder how do you know when the lifter is in correct max position before adjusting it?
Hugomartin
Banned
Nc
Hugo
Since 4,6,8 are bad how do I adjust the number 4 intake and exhaust?
bluecamden85
Ohio
Sierra
If you're going to take valve springs off I would suggest the rope method. Might wanna change the valve seals too while your at it.
zapattack
