Longer wheel studs for 1/4" spacers
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I've got a set of 2" bolt on adapters for my truck. I've had em on the rear for a good bit over a year, took the fronts off before I added more lift in the front. The 35's on a 4" lift were bad enough, pushing em 2" further out made it even worse for rubbing. Couldn't hardly make any turn without rubbing.
I love em in the rear. Just enough to make em stick out of the fender and match the front. Debating on whether I'll stick em back on the front when the engine is all back in and the body lift is all said and done. Original intent for them was to allow for easy tire rotations since the diameter of the rims are slightly different on the inside so the current rears contact the brake calipers whereas the fronts clear just fine.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Call me silly but I love the way these trucks look with the fronts out further. They look like they are flexing, or like Spike from Tom&Jerry.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I like em matching, but also miss having the front out so much more too. Without the rear spacers, you could just barely see the rear tires there.
Still have the factory spare (with nibs and all) and had to use it once to get her on home.... The absolute oddest sight seeing that tiny tire sucked way in there on a full size 4wd truck. 28-29" tire on a maybe 8" rim..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I take it you diff is open? It wouldn't have been happy otherwise, unless you have an air locker.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Open rear diff yeah, but that was when I was still on 32's as well.
Definitely planning for an elocker or an air locker though! One of these days!
thatgermanguy
