Long tube headers/dual exhaust question
87SQRBDY
Fayetteville, NC
Josh
5.7l 350
I just had long tube headers and 2 1/2" dual exhaust put on my 87R10, but I wanted to know if I should put an H pipe on it or just leave it? An X pipe would be a lot more work. Would it be any better or the same leaving it as is or not. Thank you.
Rusty Nail
Rusty
350sbc
H pipe is /wincity.
Your truck will "level up" for.sure. and you may kick yourself for not doing it sooner because it sounds F- AWESOME!
*This is the 2.25" system in my '88 Blazer 4x4.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I actually prefer the sound of a dual exhaust small block with a little bit of cam and no H pipe.
I have no valuable input in regards to power or efficiency of either set up. Allegedly a properly placed H or X scavenges better
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I love my h- pipe. The only truck I may not do it to is my grandpas truck since I want it to be like the good old days.
But personally i hate the small block popcorn. Especially 90's chevys. Straight pipe 90's Chevys makes me wanna ****** puke lol. With full length exhaust that is. Ear piercing blap blap blap blap. Sounds like their boyfriends ******** in a tunnel. The h-pipe really cleans up the exhaust noise and makes a small block sound mean with full exhaust. Even dumped before the rear tires, a stock motor with h-pipe doesn't sound like a turd.
Also its super easy to install.
87SQRBDY
Fayetteville, NC
Josh
5.7l 350
Thank you to all that responded and apologies for just now thanking y'all. I will def check out the engine masters show as well as take eveyones advice on the matter.
WesN
Edmonton Alberta Canada
Wes
C1500
I was experiencing horrible drone at 30 mph so installed the crossover. Mellowed just enough to kill the drone and enjoy cruising around town. I made it so it will come apart so one side or the other can be removed without fighting with both.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
H pipe will give a very small performance increase. not worth it IMHO.
MikeB
I've installed an H-pipe on one vehicle, and an X-pipe on another. Have to say I didn't notice much difference in sound or seat-of-the-pants performance. But it stands to reason that back pressure will be somewhat reduced with two paths for an exhaust pulse to follow.
I didn't watch the Engine Masters video above, but those guys are mostly concerned about peak horsepower at high RPMs, and sometimes get all giddy if an engine makes another 5 hp after some modification. Every once in a while they do mention the torque curve and drivability, but not very often.
75BEASTK20
B.C. CANADA
Cal
"H" pipe will give a lower growl, but like everybody else says........unless you got some serious ponys...........forget about it. You won't notice any performance difference on a stock engine. Only sound change. "X" pipes sound too 'tinny" for me. Just my opinion.
Also another good chance of a leak unless its welded in properly.
Unless you're over 300 horse, I'd leave it the way you have it. More ponys? Go "H" pipe.
75BEASTK20
B.C. CANADA
Cal
I'm putting a BLUEPRINT 540 horse 427 small block in my rig and going with 3" pipe all the way, WITH an H pipe. She needs to breathe easy.
JD Miller
Augusta, Georgia
JD
472 Cadillac
I have doug thorley long headers with big pipes and summit long turbo mufflers with short curved down tips dumping right before the rear axle . No H pipe, been running for over 20 years, :gr_grin:. H pipe is just extra crap in the way. No real world advantage. Hot rodders and racers survived for decades without a H piped exhaust pipes.
:idiot: :Big Laugh: :Big Laugh: :gr_grin:
75BEASTK20
B.C. CANADA
Cal
Are those Flowmaster 40's? If so.........do you like the sound?
Lnbaxley93
