Long bed to short bed conversion
MarshMobbin907
Fort Polk, Louisiana
Riley
Flux core is for making yard animals out of garden tools not welding frames. You want a MIG set up. And I hen welding vertically you go bottom up.
I kinda have a budget for a welder due to the wife, would flux core at least be good for body work?
Dougnsalem
I found a better idea for this post
MarshMobbin907
Riley
Oh c'mon. I guarantee most guys on here that are married have budgets set for them all the time. If not, we'd spend all the money on beer and parts lol
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Flux core is a dirty weld.
C'mon...you like it dirty...lmao
In all seriousness, a mig welder with the correct amperage setting and heat penetration will work fine for a longbed to shortbed frame modification. The metal thickness on the c 10 frames isn't very thick. You guys are trying to compare the frame thickness of a 80's Chevy truck to tractors, or tractor trailers....very funny. Tractorsor semis are used for heavier application than any c 10. This is an apples to oranges comparison.
A mig welder (110volt) will sufficiently perform the job as long as it is performed by someone with the proper skill level. Clean welds, penetration (and yes even flux core)...will do the job. Even if flux core leaves "dirty welds"...will do the job just fine. I a not suggesting that a novice welder applying booger welds, hit and skip welds will do the job by any means. If you want to do a vertical chop, go ahead...but be absolutely sure to plate as well and do a continuous weld on the plate. I opted to do a "z" cut myself..to each his own. I also used a 110v Lincoln mig welder and with the proper amperage, I was able to apply a single pass continuous weld without any issues. I also fabricated and welded my rear bridge using the SAME welder. The bridge was made using 3/16 thick rectangular steel...again with no problems whatsoever. It may take longer to weld, but it has held up fine and I am absolutely confident in my welds.
smoothandlow84
Steve
Lmao...
After 21 years of marriage. .....
What I spend on projects and toys is far different from what my wife THINKS I spend.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Lmao...
What he said. Too bad I can only likes it once like on your next 10 posts wether I likem or not lol
echo7bravo
Alabama
Adam
K-10 stepside
350/Th400, 4.56 with 35" BFG MT
LOL
All this talk about shotbed conversions. I have a short wheel base rolling chassis in my front yard I need gone.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
That's a myth started and pushed by misandry. Fact is the overwhelming majority of men will die for their women (and families). Men are noble creatures even with their beer and loud farts.
roundhouse
atlanta ga
justin
77,78,79,80 ?
LOL
Yeah
I’ve taken two shortbed trucks to the crusher because I couldn’t give them away
Lot of work to convert a half ton
If you had a 1 ton with the tall frame and Dana 60s it might be worth the effort
vkh
Western Montana
Var
C2500
So I'm in a handful of welding engineering classes. Now I'm not gonna pretend to be an expert by any means. But I asked my professor what he thought would be a better cut for shortening a frame. He thought a straight cut would be best, minimise the heat affected zone. And he's not just a desk jockey, he was an aerospace welder himself and an accomplished welding engineering. This guy is pretty damn smart, he has a good handle on every flavor of engineering and the science behind it. Figured I'd pass on what he thought.
Now not to say a fancy cut wouldn't work, it's obviously tried and proven as well.
echo7bravo
Alabama
Adam
K-10 stepside
Better cut would be for someone to cut over to Birmingham and get this 1/2 ton short wheel base out off my driveway. LOL
I'm sure the engineers know more than the DIY home fellas. But either way I think it would hold just fine. However, I think I would reinforce it with a plate either way.
vkh
Western Montana
Var
C2500
Lol, fair enough
Agreed on both counts
454-k10
CO
Rodney
If I was closer that swb would be on my trailer. :(
thatgermanguy
