- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
So all along I've been told and have thought this firewall mounted vacuum switch is for TCC (Torque Converter Clutch) lock up. So I see a post the other day and someone asking what this is. 100 people all said TCC Vac Switch for Lock Up, including myself. Some guy comes in and says it's a Tip In switch to delay timing advance on ESC controlled LE9 305 engines and 1 other that I don't recall the RPO code for.
I confirmed it IS a Tip In switch for ESC (Electronic Spark Control) vehicles.
So now that the big FAIL has been pointed out, I need to find wiring diagrams to figure out where LU comes from. I've always just plugged the wires in and it worked, and I've also seen the aftermarket switches that look very similar for LU control and have added a couple for retrofit conversions in the past on other cars and such.
