Locating odd sized bolts
A Fastenal that does not deal with the public?? Never heard of such??
I believe it started with the covid thing. The one in Springfield OH recently told us that they will no longer sell us hardware in smaller quantities. It must be 50 or more.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
I see, havent been in a long while...ours would never sell 1 or 2, you had to buy however they were packaged.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
this might be what i was speaking of, i never tried myself. i might give them a call some day
May wait till after covid, lol. But no they don't break packiging. Was normally cheaper for me to buy a pack of 50 than make a 100 mile round trip to get 5, plus always figure if I need 1 or 3 or 5 of whatever today I'll need them again at a later date. Of course I won't be able to find the 40 some odd I have and will go buy 50 more....lol
i always assume that if i have extra i will eventually need them and be unable to locate them anyway, so i will buy more then, too.
so double win, have more fasteners!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
2 things, (coming from a nobody that makes his paycheck doing tool and die making ) because this thread has lasted on for like, weeks it seems lol.
1. A threads MAXIUMUM holding power is 2.5x the diameter, that means, if you've got a 3/8-16 bolt, and you've ran 2" worth of thread in, it's a waste of time, no ifs, ands, or buts
2. If you're in a jam, just cut it down, chamfer the 60° on the sander/grinder on the end, and run it down.
Sometimes, taking a knife and knocking the burr off the leading thread helps.
CoggedBelt75
Oklahoma
Joe
we have a local fastenal... wont deal to public, only commercial accounts.
would be a god send
I find that odd also that they’re not open to the public.
its a very tiny storefront and usually has 3 employees, 2 of which are on runs for companies and 1 who mans a desk. im thinking its like what was said earlier, bulk or package only
nice
can someone tell ford this on a pre 94 4.0 v6?
Auburn, Washington
Meaning in order to get full tensile strength out of a bolt, the nut would have to be 2.5x as long as the bolt diameter?
Not sure I believe that, as most hex nuts, certainly those used in tension loads would be much longer.
I’m almost certain you can develop full tension in 1-1.25x the bolt diameter.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I’ve always heard minimum fastener engagement was equal to diameter. Couldn’t tell you maximum.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Personally, I think of the thickness of the nut for that sized bolt is enough, threading into steel. Threading into alum, cast, maluable iron etc.. softer material gets more thread engagement. That is just how I do it.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
The depth of a nut looks pretty close to the diameter of the bolt.
rt66paul
California
paul
1991 suburban
If you do modify a bolt(especially one that threads into a different alloy, be sure to use a bolt dressing(never seize or even locktite). The coating on the threads will help keep it from galling.
MikeB
Try these guys. https://www.boltdepot.com/Hex_bolts.aspx
Or just cut down the 4" bolt and grind a 45 degree angle around the diameter of the cut so it looks somewhat like the end of an uncut bolt.
BTW, unless this is a metric bolt, if the thread count 18 per inch then you have a 5/16"-18 bolt.
hotwheels03
