Lift and tire size on a daily driver...
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
How much lift and what tire size do you guys run on your daily drivers?
I was thinking 6" lift plus 37" tires but in not a tall guy and my chick is short too... I think it might end up being a pain on a daily basis unless i get those steps that drop down when you open the door.
Then i was thinkin 4" and 35" but lil jeeps run 35s and my k5 being a full size truck should run big boy tire sizes.
What do you guys think?
chevydude
arizona
hunt
k20
A 4 inch lift and 35s are a great way to go on a daily driver. Although 37 inch tires are a good size. But for a daily driver a 4 inch lift and 35s will do fine you might need a 1 inch body lift though.
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
Also have to make sure it still fits in the garage for repairs in the winter... I was thinking if i had beadlocks i could air down to fit it in but dunno the exact height the truck would be...
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I had an 8"lift w/35s, it was cool as f*%k, but not as a daily driver. And I do drive it everyday. I dropped it down to a 6" with 33s. Actually the truck doesn't look much different, but the ride quality and handling on the freeway is night & day difference. Here's some pics of before and after.
8" w/35s.
6" w/33s.
Chevrolado
McKinney, TX
Dave
K10/1500
Yeah.. I agree with the 4 - 35 combo. I think thats decent enough to look good, but not be a pain for daily use..
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
I want to make sure its not useless offroad aswell, so that's why originally i wanted 6" with 37s....
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
You will have to take into consideration how extreme with the offroading your gonna get with it.
Driver4r
Nebraska
Trevor
k10,c20
Even on 6" of lift, 37"s will run a high risk of rubbing/eating your tires on the fender.
I myself dont beleive in cutting up a body to clear tires.
I would go 4" on 35"s.
Jimbo166
Canada
c10 scottsdale
Believe it or not that extra two inches on the tire makes a huge difference on the way it rides. Have you considered a 6" with 35s?
Depending on the wheel used, that may require a little trimming. If I try, I can get my 33's to lightly rub the fenders with a 4 inch lift. Speaking of which, my wife drives it everyday and she's only 5'3". She says she could get in it just as easy if it were a couple inches taller.
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
6" with 35s makes it look like the wheels are too small.
I plan on trimming what i have to, my girls a lil rusty anyway...
I've got 33s on it with no.lift and it drives fine... But they do measure out as 31s.
Isn't a 6/37 going to lift it 9"?
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
really? i barely rub if at all with 33's and a 2 inch lift. has more to do with my bumpstops tho cuz i DEFINITELY have bottomed out many times. I may be alone on this but 33's and a 2 inch lift are my vote. I think it looks the most proportional. Even more so than stock.
It just depends on how rough I'm being with the truck. Honestly, I don't know how I haven't broke anything in the front axle... then again, it's probably the open diff. I'm sure I'll kill that axle with bigger tires and a locker.
8T6K5
AZ
L98 350 TPI
86' K5 in my sig:
4" Ranch springs and ORD 1" zero-rate up front, 4" ORD shackle flip and 1" zero rate w/56" springs in rear (5" lift) on 35X15.
I have another vehicle as my DD, but would not hesitate to use this if needed. 6/37 is too much...too much stress on your steering, 10 bolts and stock gearring for DD. Factor in the cost to upgrade and you'll think twice.
Bigger is not always better "offroad"
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
:happy160:I concur!
zacharyb
