LED question cluster
I forgot about this thread lol. Here are a couple of photos with the cheapo LEDs 6 beans on eBay
As long as you dont have flickers or ghosting issues and are satisfied with them ,they should work at one brightness for you
Chaning the color of the backlight reflector plastic and also getting a low liight output turn signal light or stacking second sets of green filters should help make them not bright. use green bulbs
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
I changed all my dash lights to LED,even the turns,all work fine and they do dim down.
richard A lindner
Florida
Richard lindner
Add up how many you need on web site look up your truck.mine look like factory 194 bulbs
Ontheboulder
colville,wa
greg
dsid you buy yours based on bulb number, vehicle entry into the websites catalog, a kit, or what did you do?
i bought this part number 194-CWCOB1W these were 135 lumen cool white. T3.25 miniature wedge base. the have a conversion table on their website. I called them when I ordered mine they were very helpful. this was not a kit, just individual bulbs. if ya go on the website it lists different bulbs and lets you know if the LED bulb is oversize in comparision to the standard bulb
Im glad that worked , the reason I asked was more so that others if needed could know that the way you got them would also work for them.
so have you only replaced your dash bulbs or do there exist incandescents on the dimming circuit anywhere? Radio, Hvac, wiper switch, PRNDL display(if not a manual), NP208 shifter, etc
The reason i am asking is if you have entirely LED bulbs on your dimming circuit and the dimming works normal, thats actually amazing and thats really really helpful to know, but if you have reg bulbs anywhere, where at? If you replace those, update us if you still have the same behavior etc
Ontheboulder
colville,wa
greg
I did replace the light on the 4x4 floor cover with LED as well, I did not do the hvac and still have incandescents on the dome and courtesy lights. I did every bulb on the back of the dash cluster
So im not sure if the dome/floor lamps will affect the dimming itself but if you make them all LED soon, id like to know how it behaves. often times old style dimmers dont do LED only very well, but its not to say that they cant. The HVAC/Radio still do dim, as does the.. wait your wipers are on the column, nevermind.
By chance, could you take a pic of your floor shifter at night with the LED lighting it?
Ontheboulder
colville,wa
greg
will do! I got an LED dome light bulb today, but right now i have the column tore apart, greasy mess!!just got the lock plate off.
brentjo
