LED question cluster
squarelyfe
NORCAL USA
Larry
k25
Is there any issue with using all LED's in the instrument cluster EXCEPT on the turn signal indicator lights? Can I mix the two safely? I'm aware that I won't be able to dim.
Corvette Ed
East Tennessee
Eli
I just did mine I replaced only the ones that illuminate the panel with LEDs,the others I left original. Be sure to test the bulbs before you put everything back together. P.S. mine are dimmable.
squarelyfe
NORCAL USA
Larry
k25
Are they the wafer style?
PunH2O
Btown Pa
Pun
From my experience they dont dim but my blue isn't bright so its perfect
squarelyfe
NORCAL USA
Larry
k25
That looks nice. I'd be interested to see a setup with red as well. What type of led did you use?
Corvette Ed
East Tennessee
Eli
I’ll try to get a pic /info on the bulb sometime tomorrow. I used ice blue bulbs.
Corvette Ed
East Tennessee
Eli
squarelyfe
NORCAL USA
Larry
k25
Do you have a photo with them lit up at night?
Doppleganger
OH-MI: Just like it sounds
There is a simple / cheap stock relay swap that works perfectly with LEDs (flashers, etc). Was a big write up on it that I (unbelievably) cannot find ATM....but I did order the relay so will check out its PN and post it. Maybe that will lead me to the article.
squarelyfe
NORCAL USA
Larry
k25
I thought that was for flashing LEDs only
Doppleganger
You said 'except the turn signal indicator lights'.....this was the round relay that allows them to work also. Guy that did it had it in a Chevy Caprice - same fuse panel - and it all worked fine.....dash, indicators, etc. I mentioned it because they can all be LED and work fine - thats my plan anyways.
As far as dimmable LED dash lights - probably on a different relay.
squarelyfe
NORCAL USA
Larry
k25
I don't want the indicator lights super bright
squarelyfe
NORCAL USA
Larry
k25
I forgot about this thread lol. Here are a couple of photos with the cheapo LEDs 6 beans on eBay
OSReaper
