If you've got early heads from pre unleaded gas era (which I believe started to really hit mainstream in like 73-74) then using a lead additive is a good idea to help protect the exhaust valve seats and keep them from wearing out- take it from me, my 1972 049 Big oval heads had seen their better days, and there was literally nothing left of the exhaust seats that were cut into the heads when it was factory new-which is basically just a seat cut right into the cast of the combustion chamber. The exhaust valves had beat themselves in a few instances across both heads up to .175 deep into what should've been the exhaust seat. Basically junk! l had hardened exhaust seats cut into and installed in mine. Machine shop attributed it to modern fuels, and being improperly set up the last go around by previous owner. He said he does a lot of period correct stuff, where the customer just wants things cleaned up, freshened up and put back together, and he always recommends some type of lead additive where old heads are being ran on modern fuels without hardened seats, or tells them to run aviation fuel, the 100LL, so that there's enough there to protect the valve train components from premature wear otherwise it will destroy the valve seats. And I believe that todays stuff is a lead type substitute of sorts. But it's mostly for nostalgia stuff. most of our squares, I say MOST should never have a need for the stuff, unless you like the smell, like race fuel, then I say dump a few gallons of the good stuff in and give it the go pedal! Lol
