LE9 305 w ESC Performance upgrades '86 k5 Blazer
mcarlo86
ND
Suburban
The restrictions in a 305 are it's awful bore size coupled with it's diminutive size with low compression, and you severely need compression @ 7,000'.
Not the heads which are normally just fine to boost compression on a 350, (unless you have the worst versions).
The cam is sometimes smaller than a 350 cam specs, but not always, and the 305 needs a very small cam to help to not lose compression - especially in a truck! But a BETTER cam always helps, Isky and Comp both make some very good tiny cams ( most truck 350's need these also).(A cam is down the list about 4th)
Add a K&N air filter to your stock airbox, but it will be expensive
Long tube headers always bring extra power and a mileage boost if you free up the remainder of the exhaust. A higher flowing single pipe system can be better than duals when done correctly with a hi-flow Y-pipe and low restriction muffler, (A mandrel bent 2.5" system). This would be priority one!
Set a new stock 350 installed with better exhaust and you'd likely gain mileage and definitely feel like double the power. And I'd use new/good 305 heads on that 350, 1.84 valves and all!!
Actually the ESC 305's had a pretty high compression ratio of around 9.5:1 or something in that neighborhood. They could do that and still run low octane pump gas because the ESC would retard the timing when it sensed spark knock/pinging.
They had high compression,decent heads,a 4 barrel and a 929 cam,there's not much you can do to them,on a budget to make any real difference. You can make them substantially worse by messing with them.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
I added dual exhaust this weekend. Stock manifolds, dual 2 1/4” with 24” magnaflow generics. Sounds good and runs stronger, mostly noticeable in the higher revs. It used to shift smooth and soft at wide open throttle. Now it has some kick. Maybe +5-10 hp. I have some videos of the exhaust sound and a walk around of the k5 on my YouTube channel.
JoeyPepperoni
