LE9 305 w ESC Performance upgrades '86 k5 Blazer
CAMSHAFT! and heads are the big restrictions on an LE9.
As far as you blue smoke at startup. If you have good oil pressure and compression it is probably jus valve seals.
That is an easy repair.
If it's got 416s or 601s they really are not bad heads, yes there are better,but there are much worse.
1979 K10
Flagstaff, Arizona
Terrell
K10, K5
I'll have to look for the head casting numbers where ever those are. The engine is caked in 40 years of oil and dirt.
More work than you want to do just to satisfy curiosity.. cast into the head by the rocker arms underneath the valve covers. Seriously if you want performance,change engines. Or put boost on that one. Swap your boost to the next engine when this one dies. Not kidding
Turbo4whl
Downingtown, PA
Wayne
^^^ BOOST^^^
When you think about newer vehicles, they mostly have smaller displacement engines. So how do they have enough power? Boost is the answer.
hack_man
MA
Tony
Where is the ESC Module located? Does this work with the knock sensor to retard timing?
I remember there was a TSB back in the 80's, my 305 was pinging and the dealer installed two small canisters tied to the vacuum line at the distributor. I think they acted to delay vacuum advance.
I tried to get a copy of that TSB but they refused.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I remember there was a TSB back in the 80's, my 305 was pinging and the dealer installed two small canisters tied to the vacuum line at the distributor. I tried to get a copy of that TSB but I remember them refusing.
If I’m recalling correctly, the esc box is in the cab behind the glove box area. Wires should run from the large plug on the firewall above the passenger side cylinder head.
It works with the knock sensor to pull timing.
hack_man
MA
Tony
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
If you start having intermittent starting problems that you can chase down to lose of spark, I would look at the ESC. You can buy a $20 bypass loop cable on ebay to disable/bypass the ESC, and leave all the ESC stuff in place. Check the timing after disconnecting the ESC, it will probably be a little too far advanced.
SirRobyn0
Rob
I can confirm that the ESC module is located behind the glove box. The best access is to clear out your glove box and remove the box itself.
I would advise against any kind of a bypass or elimination of the ESC, like the bypass loop mentioned in the post above this one. It's fine if you want to do that for testing purposes though.
1979 K10
Flagstaff, Arizona
Terrell
K10, K5
Looks like the previous owner replaced the distributor. How do I check the timing since mine is ESC equipped?
I live at 7000 feet altitude so we usually advance timing for our elevation
huss 440
