squaredeal91
- Mar 10, 2023
- Cave junction Oregon
- Greg bush
- 1991 SB
- K30
- 5.9 Cummins 12 valve
1999 K1500 suburban interior lights will not shut off unless I unplug the fuse. Dome override button doesn't change anything witch is weird. Tried a different switch and no change. vehicle been sitting 4 years. Fixed lots of things and did lots of maintenance to get it back on the road. Runs and drives great! But now suddenly lights stay on.
When driving with lights on the chime screams at you even with light fuse out. so night driving is NO. Fuse no 3 controls the lights. Assuming it's not the switch at this point.
Either a shorted wire or bad door switch. Driver door is ruled out because I can leave the key in ignition ant it will scream till I close the door and it goes away. So it's in one of the other 5 doors?
Anyone els have something similar? Probably not related but alternator just died too.
Hoping someone else has some good ideas. I'm probably going to have to check all the switches tho.
