Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
Not sure until I pull the th400/208 apart. My 4500 will be here Tuesday. I’ll be able to better wrap my head around it then. I’ll be diving in next week. Just some prep this weekend, might pull the 400/208...Franken-
I've been trying to figure out how one changes the rear deal in the 4500 (4wd). From what I can tell, there is no seal in the adapter and the space inside the adapter will contain fluid for the 5tth gear.
However, there had to be a seal on the output shaft between the trans case and the extension?
You any info on this?
I’m going to weld up a crossmember to avoid the 4” block spacer. Seems like a better idea than plopping a chunk of 4” box tubing on top of the existing flat crossmember.
