EcoK20
- Apr 13, 2022
- Owasso, OK
- Joseph
- K20
So I thought I'd share some of what I'm working on since it's got a lot of things that I haven't seen all put into one package and figured someone might find useful information in what I'm doing. I've been planning this project for some time, and recently felt like I had enough parts and was healthy enough to start. I'm working with a low mile 1980 K20 that started life with a 292, SM465 and an NP205. I picked it up at an auction in rural OK for what I felt like was a good deal. I got it running and drove it for a while but didn't feel like it was very user friendly. I wanted something with better mpg, an overdrive, and overall better for modern driving. I had a low mile LV3 from a 2014 silverado left over from another project that was nixed. I thought that would make a great engine for what I'm hoping is a good daily driver. I debated transmissions for a while and decided I wanted a TR6060. The unit I'm using is from a 2010 camaro. After having removed an np203, I did not want to have to work on a 205 with their weight. I know they are bulletproof, but way overkill for what I'm wanting. I found an np241 passenger drop transfer case to use. To mate the gen V engine to the TR6060 requires an 8 bolt flywheel. A manual was never optioned behind a gen V in the truck application, BUT the LSA uses an 8 bolt crank. I picked up a dual mass clutch and flywheel on ebay and bolted it on. Gen V engines require a 3/8" bell housing spacer because the cranks aren't bored deep enough for the snout of the 6060 (maybe other manuals as well). To mate the tr6060 to an np241 requires some work. The options I was able to find were cost prohibitive, so I made my own adapter. This requires the transmission to be completely disassembled, a corvette output shaft to be installed and a corvette tailhousing to replace the 2wd camaro housing. Then you have a flange to bolt to. I had a plate cut and machined to fit, and a "snout" to bolt to the plate that also has a bolt pattern to bolt the cast iron transfercase mid-mount thing to. note: if you two-bolt the top two bolt holes on the tailhousing, you will need to clock the transfer case pattern approximately 9* to be "level". I'm using Tejas engine mounts and still needed to clearance my v8 crossmember for the oil pan. I'm at the point of drilling out my frame to move the trans crossmember back. Truck shown on a scale at 5060lbs. More updates to come
