Just bought a 87 Tbi original swb... Looking for best mods for it
Kidknapp
Jeffrey
Will post pics when I get back in town.
87k original miles, white with red interior
Saw the steering shaft mod, and wondering what else I should look to upgrade.
May change interior color to black/charcoal
Thanks for any advice
Knapper
74 Shortbed
Welcome to the site.
1973c10
Don
Welcome abroad
can't wait to see pic of your truck
I did a black interior in mine and like it
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Sounds small, but the 1/2 inch pex pipe door striker bushing makes a bit of difference.
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Or just buy the replacement striker pins from NAPA :yawn::)
What's up new guy!! Welcome! Now let's see some photos!
Kidknapp
Jeffrey
Not my truck, but love the wheels and drop
anybody have a idea on size of wheel and tire.. And who is the wheel maker ?
Thanks
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Looks like a static 5" front and 7" rear drop...with 22" wheels. I have a 5-7 drop with 20" wheels and it appears to be pretty close. It could maybe be air bagged as well, just sitting a bit aired down for the pic.
Camar068
10 yrs Air Force
Nice. You could look up the headlight mod. By adding relays you'll run power straight from the battery to your headlights making them brighter. Build your own harness or if I remember correctly, harness's are available for ~$35.
You could also do the auto-dim w/temp rear view mirror. Fleabay for ~$55.
Kidknapp
Jeffrey
Nice
I'll look at them
I thought about stock looking LED headlights would be nice.
Thanks
Kidknapp
Jeffrey
Nice Truck
What size tired u running on 20's
smoothandlow84
Steve
Nice Truck
Thanks...
Fronts...255/45r20....rears...305/40r20
Fronts are 20x8....rears 20x10
Kidknapp
Jeffrey
Any ideas on the wheel maker on the red/silver truck ?
Rusty Nail
Rusty
350sbc
Aftermarket rocker arms are one of the best performance mods ever. Consider the 1.52 Comp Cams roller-tips as the best place to get the best bang for your buck.
smoothandlow84
Steve
Replace the oem rubber control arm bushings with polyurethane units. Well worth the time and effort! Replacing tightens up the front end and polyurethane wont wear out like rubber. I would also replace the front sway bar bushings with polyurethane as well. Replace the rag joint to tighten up the steering....and check the frame where he steering box bolts on for stress cracks (very common with these trucks to develop cracks there). If cracks are found they can be weld repaired and frame reinforced with steel plating. Unlike late model rack and pinion steering, there are more moving parts and linkage which if not maintained cause sloppy handling. Check ball joints, pitman arm and idlers for sloppiness.
m4chine
