So I'm doing a little messing around with numbers, figuring out why the 2017 Denali with the 6.2 liter has such a hole shot, even though it is a heavier (crew cab instead of regular cab) truck.
Here's the numbers on my 78 Cheyenne K-10 first:
1st gear on a TH350 is 2.5:1, and the rear axle ratio is 3.73:1. So a combined 9.325:1 in first.
Max torque: 420 ftlbs with the cam I'm running. So total torque at the wheels is 3916 ftlb.
Tires are 31" diameter, so 15.5" radius, which is 1.29 feet.
Total thrust at the wheels, assuming I can hook up, is 3035 lbs.
Truck is 4800 pounds, so maximum possible acceleration is .63g, or 20 ft/sec^2.
For the Denali the numbers are:
1st gear on the 8L90E is 4.65:1, and the rear axle ratio is 3.23:1. So a combined 15.02:1 in first.
Max torque: 460 ftlbs with 6.2 liter. So total torque at the wheels is 6908 ftlb.
Tires are 31.7" diameter, so 15.8" radius, which is 1.32 feet.
Total thrust at the wheels, assuming I can hook up, is 5233 lbs.
Truck is 5500 pounds, so maximum possible acceleration is .95g, or 30 ft/sec^2.
So half again the acceleration of the cammed 350 with 3.73:1 in the lighter vehicle.
Yowza.
