bluex
- May 9, 2013
- Spartanburg SC
- Paul
- C15
Heres how I got the Jeep steering shaft to work on my early column.
First I did the normal stuff, took the shaft apart and cleaned it up. Then I took the upper joint, the one that wont match and early column and cut it up to get it off. You'll also have to cut off that smaller crimped section of the shaft as well.
Go to Ebay and order one of these 1"-48 to 1"DD universals:
https://www.ebay.com/itm/1-48-splin...ash=item4d1493fe97:g:MVkAAOxyXDhSdB2C&vxp=mtr
Put that on the shaft mark the two securing holes and drill them. I drilled mine through and tapped to 5/16-18 to make sure it holds tight. Assemble with red loctite and install. Enjoy, ya its not as cheap as just a Jeep shaft alone but it also isnt almost $300 like the aftermarket stuff.
