ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
Apologies in advance for a jack question, but I haven’t seen exactly what I’m asking about.
1. What are the differences in stock engine bay jacks throughout the years? I wouldn’t mind finding one for mine, it’s an ‘81.
2. Do they suck that bad? I’m not totally hung up on using only this- far from it, but I do want to have one in the vehicle and aside from a bottle jack, not sure what would fit behind the seat.
I do like the fact that they appear to have a broad base, and the lift surface has a contour to it to help keep it from slipping. For that reason, I’m less of a fan of a standard bottle jack, since the contact patch is small and often times the shoulder of the road is cambered.
Or any other tidy solutions that don’t take up a lot of space that are a relatively safe option- I’d probably be jacking from the front frame rail or rear axle in a must-do situation. I have tubular a-arms on the front so really no flat surface for support there that I’d consider, and it would likely damage them anyway.
Thanks in advance.
Thanks in advance.
