SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
I needed to address the upper radiator hose. You see, with the serpentine drive and my aftermarket aluminum radiator, I had to figure out a hose that fit the bill. The upper hose is an OEM hose for a 67 Firebird with a sb 400.
Only problem was it sagged under the weight and touched the back of the alternator. So, I fabricated a support bracket that uses the alternator mounting bolt. Functionally, it works perfect!
I plan to fire the beast up tommorow.
