Is there a way to remove this....
DanMcG
Central NY
k10 k10
tag with out destroying it? or does someone reproduce it? I'd like to remove it for some body work and then reinstall. I've never had any luck doing it.
thanks.
75gmck25
Northern Virginia
Bruce
When I swapped the RPO code sticker out of my glove box I first took a very focused high resolution picture of it, and printed the picture to make sure the color and all details were accurate. Then I put wide, clear mailing tape over the picture to give it a solid surface, and glued the new “sticker “ onto the glove box.
Bruce
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Heat gun or hair drier. Just don't get too hot with the heat gun as it will melt it and should peel off slowly using razor blade or exacto knife to peel up.
DanMcG
Central NY
k10 k10
Thanks for the tips guys!
Nuggets40
