intake Manifolds
would you run edelbrock or holley?
  • edelbrock
    Votes: 40 74.1%
  • holley
    Votes: 14 25.9%
  • Total voters
    54
cfieldchevy
Maryland
George
Oh i see the pic, stamped.
79K10
Sacramento,ca
Ryan
350/th350
Oh the pic at the beginning of this thread? I don't have that truck anymore... I've got roller tip rockers on this one... Suppose they are stamped too though right? I'll take a pic when I get the covers off in the morning
79K10
Sacramento,ca
Ryan
350/th350
So it wasn't the rockers making the noise, I pulled the dipstick out and it looks like it was rubbing the crank... New stick, no more tap.
firebane
Calgary, AB
Curtis
Check and make 100% sure you have the lower tube in your block. If you don't your dipstick will do the same thing again.
99% of rebuilt engines do not have this and most people don't even realize its missing.
79K10
Sacramento,ca
Ryan
350/th350
Wouldn't that mean pulling the pan off? The tube would push up from the bottom if it was there? I don't see anything from the top side
firebane
Calgary, AB
Curtis
Yes you have to pull the pan to see if the tube exists. If it doesn't then you need to install one otherwise the dipstick can slap against the crank all the time.
79K10
Sacramento,ca
Ryan
350/th350
Great thanks lol .....
doesn't seem to be hitting, I'm gonna let it go for now... Thinking a pan gasket will be needed before summer is over so I'll check then
Ghetto
Hampton NH
Pete
4.1 6 Banger
On our 38 Ford we are running a performer intake with a Holley 600 and the matching edelbrock cam. Runs and sounds awesome! Has block hugger headers with some cheap universal turbo style mufflers.
mswed
