Installing windshield in a Squarebody
JBswth
Vallejo, California
James
C25
292 cubic inches
My first time installing a windshield. I have seen on U-Tube that the rubber channel is supposed to go on the pinch-weld and the windshield installed that. We have been trying that method and broke two windshields. I always though that you put the channel on the windshield and rope the windshield in. Why the change?
James
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
I've never heard of installing the gasket on the pinch weld first.. My guess is you've been watching the wrong video.. Just because it's on the internet doesn't mean it's true, or in this case, correct.
scrap--metal
MN
Calvin
'85, '81
K10, K20
What's causing them to break? What's different between your experience and the videos you've watched?
Putting the gasket on the pinch weld first, and then fitting the windshield in place is the correct way. At least it worked for me.
Make sure you have the appropriate hand tools (eg plastic pry bars and a round nose pick).
JBswth
Vallejo, California
James
C25
292 cubic inches
So true.
hogdaddy
Alabama
mike
Scottsdale
I helped the glass guy put my windshield in and he put it on the pinch weld first and used the hook tool like in the Precision video.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Pinch weld first yes, glass second as stated above. We had to do ours twice because Easton chose a one piece gasket first and once installed had large gaps and leaked everywhere. Went to a two piece and been dry ever since. Used Precision gaskets.
hogdaddy
Alabama
mike
Scottsdale
I told the glass guy to leave me with the lock strip. I soaked it in warm soapy water and used the proper tool.
Bennyt
Surprise
Ben
Are you using used windshields? Could that be issue?
I can't find/buy a windshield cheap enough to do myself. I can get a glass company to install for $30-50 more than what I can find them for.
Depends on the weatherstripping. If it's the factory type with a lock strip, you put the rubber on the pinch weld and then install the glass. Then install the lock strip.
If you have the aftermarket type weatherstripping without a lock strip, you have to put it on the glass and then install it with a rope.
I've never had trouble getting the glass in, it's just the lock strip that's tedious. But certainly doable, even without the proper tools.
JBswth
Vallejo, California
James
C25
292 cubic inches
I have one of each, but I think I will have the pros do it - if they break it, they replace it, but if I break it, I have to replace it.
James
waterpirate
delaware
v10
5.7 tbi
Do you have the correct gasket? Trust me they all look alike. I supplied the glass guy with the new gasket I bought from LMC. Vracked the windshield. Glass guy came back with new glass and his gasket and it went right in. The two gaskets were close, but you could see differences.
2manysquares2care
