installing radiator with aftermarket?
74 Shortbed
Gotta use distilled water with an aluminum radiator..
Battlac40
New Mexico
James
K1500 Sierra Classic
That why my friends factory equipped vehicles with aluminum radiators have ground straps.
The timing chain's friction generates electricity, the WaterPump also generates electricity.
It needs somewhere to go.
Without getting into PhysicsIII..
Ground your radiator.
I lost a brand new BECOOL aluminum badass to basically no strap in the box.
Ouch $600+ there not cheap. :shocked:
74 Shortbed
That sucks..
Battlac40
New Mexico
James
I ended up installing a carquest radiator in my c3500 dump truck, I had to remove the rubber mounts and trim the fan shroud . to make it fit. It was was suppose to be a direct fit , yeah right! My question do you think the radiator will be fine without have the rubber bushing installed on the bottom or the top bracket? It doesn't move at all and the brackets fit tightly over the top.
Thumbs down ! There must be no metal to metal contact "hanging" your radiator. It will rub. They make multiple different top brackets and I believe 7 different radiators for our trucks. Shop wisley, with your reciept and mearsuments.
Battlac40
New Mexico
James
I Always run all my vehicles on distilles water.
If my babies dont like solids
We are on a liquid Diet Lol :happy160:
75Monza
Colville, Washington
K30, K20, K20
Electrolysis with Aluminum radiators can be caused by multiple things, while grounding the radiator with a strap may help, it's not the cure-all because your connecting dissimilar metals together to make the strap and aluminum will end up with a thin film of oxidation at the contact point when you flow voltage through it. Electrolysis is caused by stray voltage in the engine, either by static of moving parts, the starter, poor body or engine grounds or alternator overcharging to name what I can think of. Regardless, to know for sure, you need to test for electrolysis first to see what your individual system has...here is what Ron Davis radiators has for a testing method. http://www.rondavisradiators.com/tech.htm
Most that I've done is just make sure that I've got "ground zero" on all my grounds (for those who don't have expensive meters, easier to find testing for voltage drop) and then I use a zinc sacrificial anode like these from flex-a-lite https://www.rotometals.com/flex-a-l...MIhen6_4S81wIVkFx-Ch3LLQUIEAkYASABEgLAAvD_BwE , I run a 50/50 mix because my temps get pretty low around here, mix my own and always use de-min water so no extra minerals get added that can cause corrosion.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
So I guess the water hose was NOT the best source for refilling my radiators? Whoops...
75Monza
K30, K20, K20
Only fords get to drink from the faucet. Bowtie deserves at least Aquafina. :boti:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
You let Fords drink ?lol my radiator is bolted directly to the rad support and well has 5 plus extra grounds threw out.:D
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
That's how I fill mine lol.
BTW, Aluminum radiators should be grounded, helps slow electrolysis.
Camar068
10 yrs Air Force
1973c10
Don
How long will aluminum radiator last if you do nothing
I have had one in my 75 Bowtie for 12 years and did nothing but put it in
and fill it with 50/50 LOL
Jvk12280
