Inner Rocker, Outer Rocker, Inner Cab Corner, Kick Panel & Floor Replacement
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Pics
Tank6x2
Kurt
C30
Cancerous biotch
Tank6x2
Kurt
C30
Corrosion
Tank6x2
Kurt
C30
Not big enough, get a bigger panel to get all the rust.
Tank6x2
Kurt
C30
Modify and Cab Support
Tank6x2
Kurt
C30
Cab support and securement plate
Tank6x2
Kurt
C30
Cab support overkill
Tank6x2
Kurt
C30
Fitment
Tank6x2
Kurt
C30
Excuses to the wife to buy tools!
Tank6x2
Kurt
C30
Fitting trimming and
Tank6x2
Kurt
C30
Now do I modify my hinges to get the door to fit - new made in Taiwan
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
Dang..... that’s why I run from trucks when guys say they just did rockers and cab corners. No one goes to this length to do it correctly. Nice job!
Ben
Tank6x2
Kurt
C30
Ben
Thank you sir, I’m not a Bodyman, just a welder and heavy equipment technician so that means a lot.
Tank6x2
Kurt
C30
Ben
I’ve got a whole build thread called ground up restoration, full custom four link and front suspension, but may not be your cup of joe, ended up posting this up because there is nothing I have found out on the inter web that shows anywhere near the process.
86 SCOTTSDALE
Oakham MA
Armand
I feel your pain, I went through this 6 years ago.
phil97
