In the throes of completion SQUAREMAX L5P
Rick Shootist
Off-highway farm FL
6.6 D-Max
I'm trying to upload a photo of the bed on the rotisserie but it keeps turning into a .HEIC file and then I can't find it. I don't know.
Rick Shootist
Off-highway farm FL
6.6 D-Max
CUCVs only came with one tank. I'd like to add the passenger side tank also, is LMC Truck the best place to buy all that? Any recommendations on a hitch? Thanks in advance.
waterpirate
delaware
v10
5.7 tbi
I really dig the twin sticks! Nice looking rig and it is beyond obvious the $hit ton of money that made that project go. lol
louu
South NJ
Lou
C3500
454 for now working on LS
Amazing work, need more pictures
SquareRoot
Redeemed! Knarly build. I can appreciate the work that's gone into it.
Rick Shootist
Off-highway farm FL
6.6 D-Max
so far my research shows 34" frame width on a 1 Ton chassis was likely a C&C, hence the narrower 14 bolt axle on same. 37" looks to be C/K 10/20/30. Reason I ask is that the "deep drop" 16k hitch is only available for the 34" frame width. I can fab something up but bolt in would be nicer. Thoughts?
I thought a cab and chassis had a longer spring set but the same location as a cucv.
Maybe that would be the same.
Hmm
The narrower rails does allow a dually. Better that is. Is the trailer hitch a straight piece with two backward facing supports? Can you show us a pic?
Rick Shootist
Off-highway farm FL
6.6 D-Max
1986 Chevrolet C/K Series Pickup - Draw-Tite Ultra Frame Trailer Hitch Receiver - Custom Fit - Class IV - 2"
  • Class IV
  • 2 Inch Hitch
  • 12000
  • Draw-Tite
  • Concealed Cross Tube
  • 1200
  • 15000 lbs WD GTW
  • Custom Fit Hitch
  • 1500 lbs WD TW
Specially designed to meet your heavy-duty towing needs, this fully welded, corrosion-resistant Chevrolet C/K Series Pickup trailer hitch receiver features Draw-Tite's Tested Tough guarantee, ensuring performance that exceeds industry standards.
Features:
  • Custom-fit trailer hitch lets you tow a trailer or carry a bike rack or cargo carrier with your vehicle
  • Computer-aided, fully welded steel construction ensures strength and durability
  • Tested Tough - safety and reliability criteria exceed industry standards
  • Easy, bolt-on installation - no welding required
    • Complete hardware kit and installation instructions included
  • Lifetime technical support from the experts at etrailer.com
  • Black powder coat finish covers e-coat base for superior rust protection
  • Sturdy, square-tube design
  • Ball mount, pin and clip sold separately
Specs:
  • Receiver opening: 2" x 2"
  • Rating: Class IV
    • Maximum gross trailer weight: 12,000 lbs
      • Maximum GTW when used with weight distribution: 15,000 lbs
    • Maximum tongue weight: 1,200 lbs
      • Maximum TW when used with weight distribution: 1,500 lbs
  • Limited lifetime warranty
NOTE: Vehicle's must have 34" spacing and a minimum of 19" from the end of the frame rail to the spring shackle bracket.
Rick Shootist
Off-highway farm FL
6.6 D-Max
C&C has a narrower axle for sure. Can be SRW or more commonly DRW but narrower than C/K. If necessary I'll wait for the truck to be back home in a couple of weeks.
2tank
Michigan
Bryston
I used a curt C15800 on my 90 v3500 srw. It fit great, and is super nice and heavy. I also purchased through e trailer. Additionally I installed a b&w turnover ball in the bed (97-1401). I will have to move it slightly (aligned the ball over the rear axle before putting the bed on) because the plate interferes with one of the bed crossmembers. This was due to my own incompetence (installing with no bed at the time) not the product. It will fit great after the slight adjustment I'll make when replacing the bed.
ExtraZ
