In dash plug for PW and PL
needsmorecowbell
Madison, Ms
Charles
C-15
First time posting. I have an 86 sierra classic step side. It came with power windows and locks. My question is what do the plugs look like that the passenger door plugs up to in the dash. The door is a replacement due to the original one missing when i purchased the truck. I cant get the only plugs i see in the dash to match to the plugs coming out of the door.
The first image is the plugs in the dash.
The second and third photo are the plugs coming out of the door.
What do i have here?
DanMcG
Central NY
k10 k10
I looked at the 80 wiring harness that i just pulled , but it only has a 4 wire connector.
I can look at my 85 and get ya a pic when the sun comes up.
Not sure this will help or not. This is my 85's connectors, just two fo them in my system, yours seems to be 3 connectors.
you should be able to match the wire colors from the male and female to hook them up.
Just reread your post, I'm guessing you door wiring is from a different year, and you might have to do some cutting and splicing
needsmorecowbell
Madison, Ms
Charles
C-15
Thanks I think ill just have to cut splice the wires the colors match but the plugs dont.
hatzie
k20
You can re-terminate the door wiring using the correct shells. I'd go that route rather than butt splicing it.
The part numbers for the shells are in the GM wiring diagrams. Mouser Electronics has many of the shells that aren't obsolete.
gmachinz
Harnessworx Inc
Iowa
Jabin
The 2 and 3 cavity male pack-con connectors are soon to be obsolete so in my door harness kits I have gone to 280-series metri-pack for most of the mating connectors.
gmachinz
Harnessworx Inc
Iowa
Jabin
If you need the correct shells and terminals let me know-I stock nearly everything for these trucks from 73-up. I have some experience offering NEW harnesses for these trucks unlike what anybody else is likely to ever offer so I can help ya out. For example...a CC window/lock harness...
gmachinz
Harnessworx Inc
Iowa
Jabin
zapattack
